How should I Write data in a SD memory and read it through SPI ?
there isn't no Idea ?
Do you have a dubugger you can use to check the data resulting from each SPI operation with the SD card? Or an oscilloscope to manually check the data? Without that you're going to have a hard time debugging anything.
One thing I see in your code is that you don't use CMD8 anywhere. CMD8 is required (I believe) to initialize SDHC cards (you said your card is 8GB, so it must be SDHC).
I also recommend that you at least start out with the drivers provided by microchip. They at the very least should work, and if you want you can optimize them for your needs. If you don't have the patience to reinvent the wheel, then don't do it.
Reactions: FvM
    FvM
here is codes for have communication with SD card, it's written for code vision compiler and I have problem with these lines 69,70,76,77,129,132,134 please explain these line completely, if I can understand this program I can change it for mikroc compiler. and my problem will solve, meanwhile what are "SPCR and Spsr ?
#include <mega32.h>
#include <delay.h>
#define MMC_CS_PORT            PORTB
#define MMC_CS_DDR             DDRB
#define MMC_CS_PIN              4
// MMC commands  (taken from sandisk MMC reference)
#define MMC_GO_IDLE_STATE           0          // initialize card to spi-type access
#define MMC_SEND_OP_COND            1         // set card operational mode
#define MMC_SEND_CSD                9         // get card"s CSD
#define MMC_SEND_CID                10        // get card's CID
#define MMC_SEND_STATE              13
#define MMC_SET_BLOCKLEN            16       //set number of byte to transferblock
#define MMC_READ_SINGLE_BLOCK       17       //read a block
#define MMC_WRITE_BLOCK             24       //write a block
#define MMC_PROGRAM_CSD             27
#define MMC_SET_WRITE_PROT          28
#define MMC_CLR_WRITE_PROT          29
#define MMC_SEND_WRITE_PORT         30
#define MMC_TAG_SECTOR_START        32
#define MMC_TAG_SECTOR_END          33
#define MMC_UNTAG_SECTOR            34
#define MMC_TAG_ERASE_GROUP_START   35       // sets beginning of erase group(mass erase)
#define MMC_TAG_ERASE_GROUP_END     36       //sets end of erase group (mass erase)
#define MMC_UNTAG_ERASE_GROUP       37
#define MMC_ERASE                   38
#define MMC_CRC_ON_OFF              59
#define MMC_R1_BUSY                 0X80
#define MMC_R1_PARAMETER            0X40
#define MMC_R1_ADDRESS              0X20
#define MMC_R1_ERASE_SEQ            0X10
#define MMC_R1_COM_CRC              0X08
#define MMC_R1_ILLEGAL_COM          0X04
#define MMC_R1_ERASE_RESET          0X02
#define MMC_R1_IDLE_STATE           0X01
#define MMC_STARTBLOCK_READ         0XFE
#define MMC_STARTBLOCK_WRITE        0XFE
#define MMC_STARTBLOCK_MWRITE       0XFC
#define MMC_STOPTRAN_WRITE          0XFD
#define MMC_DE_MASK                 0X1F
#define MMC_DE_ERROR                 0X01
#define MMC_DE_CC_ERROR              0X02
#define MMC_DE_ECC_FAIL              0X04
#define MMC_DE_OUT_OF_RANGE          0X04
#define MMC_DE_CARD_LOCKED           0X04
#define MMC_DR_MASK                   0X1F
#define MMC_DR_ACCEPT                 0X05
#define MMC_DR_REJECT_CRC             0X0B
#define MMC_DR_REJECT_WRITE_ERROR     0X0D
void mmclint(void);
unsigned char mmcreset(void);
unsigned char mmcsendcommand(unsigned char cmd, unsigned long int argument);
unsigned char mmcread(unsigned long int sector, unsigned char* buffer);
unsigned char mmcwrite(unsigned long int sector, unsigned char* buffer);
unsigned char mmccommand(unsigned char cmd, unsigned long int argument);
void spilnit()
PORT.7=1;
DDRB.7=1;
DDRB.6=0;
DDRB.5=1;
DDRB.4=1;
69) SPCR=0X52;
70) SPCR=0X00;
unsigned char spitransferbyte(unsigned char data)
unsigned char received =0;
76) SPDR = data;
77) while(!(SPSR&(1<<7)));
received = SPDR;
return (received);
void mmclnit(void)
spilint();
MMC_CS_DDR.MMC_CS_PIN=1;
MMC_CS_PORT.MMC_CS_PIN=1;
unsigned char mmcreset(void){
unsigned char i;
unsigned char retry;
unsigned char r1=0;
retry=0;
do{
for(i=0;i<10;i++)   spitransferbyte(0xff);        // send dummy byte with CS high before accessing
r1= mmcsendcommand(MMC_GO_IDEL_STATE,0);                   //resetting card go to spi mode
retry++;
98) if(retry>10)  return-1;
}while(r1 != 0X01);
retry=0;
do
r1= mmcsendcommand(MMC_SEND_OP_COND,0);                // initializing card for operation
retry++;
if(retry>100)return-1;
}while(r1);
r1= mmcsendcommand(MMC_CRC_ON,0);              //turn off CRC checking to simplify communication
r1=mmcsendcommand(MMC_SET_BLOCKLEN,512);
return 0;
unsigned char mmcsendcommand(unsigned char cmd, unsigned long argument){
unsigned char r1;
MMC_CS_DDR.MMC_CS_PIN=0;                               //assert chip select
r1= mmccommand(cmd,argument);              //issue the command
return r1;
123) char mmcread(unsigned long int sector,unsigned char* buffer )
unsigned char r1;
unsigned i;
portd.f1=0;
129) r1= mmccommand(MMC_READ_SINGLE_BLOCK,sector<<9);
if (r1!=0X00)
return r1;
132) while(spitransferbyte(0xff)!=MMC_STARTBLOCK_READ);
for (i=0;i<0X200;i++)
134) *buffer++ = spitransferbyte(0xff);
return 0;
unsigned char mmcwrite(unsigned long int sector,unsigned char* buffer ){
unsigned char r1;
unsigned int i;
//issue command
r1=mmccommand(MMC_WRITE_BLOCK,sector<<9);
if(r1 != 0X00)
return r1;
spitransferbyte(0xff)                         // send dummy
spitransferbyte(MMC_STARTBLOCK_WRITE);                      //send data start token
for (i=0; i<512; i++)
156) spitransferbyte(*buffer++);
r1=spitransferbyte(0xff);                        // write 16-bit crc (dummy values)
                                                 // read data response token
if((r1&MMC_DR_MASK)!= MMC_DR_ACCEPT)
return r1;
164) while(!spitransferbyte(0xff));
MMC_CS_PORT.MMC_CS_PIN=1;                           //CS
return 0;                                // return succes
unsigned char mmccommand(unsigned char cmd,unsigned long int argument){
char r1;
char retry=0;
//send command
spi_write(cmd |0x40);
spi_write(argument>>24);
spi_write(argument>>16);
spi_write(argument>>8);
spi_write(argument);
spi_write(0x95);                            //crc valid only for mmc_go_idle_state
175) while((r1 = spitransferbyte(0xff))==0xff)
176) if(retry++ > 8) break;
177) return r1;
char write_buf[512], read_buf[512];
void main(void) {
unsigned int i;
unsigned long int sector;
  mmclnit();
  mmcreset();
for (i=0;i<512;i++)
write_buf[i]=i;
sector=5;
mmcwrite(sector,write_buf);      // write to sector 5
delay_ms(1);
mmcread(sector,read_buf);        // read of sector 5
while(1)
#include <mega32.h>
#include <delay.h>
void mmclint(void);
void spilnit()
PORT.7=1;
DDRB.7=1;
DDRB.6=0;
DDRB.5=1;
DDRB.4=1;
69) SPCR=0X52;
70) SPCR=0X00;
76) SPDR = data;
received = SPDR;
return (received);
void mmclnit(void)
spilint();
unsigned char i;
unsigned char r1=0;
retry=0;
do{
retry++;
}while(r1 != 0X01);
retry=0;
do
retry++;
}while(r1);
return 0;
unsigned char r1;
return r1;
unsigned char r1;
unsigned i;
portd.f1=0;
if (r1!=0X00)
return r1;
return 0;
unsigned char r1;
unsigned int i;
//issue command
if(r1 != 0X00)
return r1;
return r1;
Line 69 configures and enables the SPI interface. Then line 70 clears the configuration and disables it. Maybe that's you're problem?
SPCR is the register which controls most of the behavior of the SPI peripheral. See the MCU datasheet for more details. SPSR is the status register for the SPI. Again, look at the datasheet to see what its contents mean.
Line 76 is just initiating a SPI transfer by writing the data register SPDR. Then line 77 waits until the transfer is finished before reading the received data from SPDR.
Line 129 just sends a command to initiate a single block read, and return the R1 response from the SD card.
Line 132 looks for a token from the SD card which indicates the start of a block read.
Line 134 takes each byte read from the SD card block and transfers it into your data buffer.
Reactions: mf1364
    mf1364
could you please explain , what do the "* " in the line 123?and about line 129, what does mean sector<<9 ? and why sector has shifted 9 bits to left? (please completely ) and do you have any idea about these lines 175,176,177 ? i want to know what do these lines exactly ? how many times the SPI is reading the bus ? just one or 8 ? totally i can understand these lines .
unsigned char* buffer is a function argument passed "by reference", in other words, buffer contains an address value, it's a pointer. Refer to your favourite C text book or tutorial for details
sector<<9 multiplies by 512, calculates a byte address from a sector number
return r1;
Waits up to 8 byte reads (64 clock cycles, as specified for NCR) for a non 0xFF response.
FVM, I think I should config SPI my self and don't use the SPI library of the mikro c so decided to config SPI same as same the above codes so could you please do me a favor and have look at them meanwhile, do should I use just SS pin as chip select and it's not possible to use another pin as a chip select pin ? unfortunately I didn't get the right R1 response and still I receive Zero !!!! instead of 1, do you have any idea ? i am so confusing
// */ my spi function
char* text = "mikroElektronika";
unsigned short  x=110;
unsigned char take, buffer;
char txt[6];
char r2=1;
char r1=0;
char bit=0;
char flag1=0;
char debounce = 30;
char count1=0;
void mmclnit()
trisc.f3=0;  // SCK
portc.f3=1;
trisc.f4=1;  // SDI
trisc.f5=0;  // SDO
sspcon1=0b00100010;
SSPSTAT = 0b01000000;
INTCON.GIE  = 1;
INTCON.PEIE = 1;
trisd.f1=0;        //CS
portd.f1=1;
 char spitransferbyte(char data)
 char received =0;
SSPBUF = data;
while(!(PIR1.SSPIF)); PIR1.SSPIF=0;
return received;
//////////////////////////////////////////LCD
void lcd(){
     Lcd_Cmd(Lcd_CLEAR);       // Clear display
     Lcd_Cmd(Lcd_CURSOR_OFF);  // Turn cursor off
     Lcd_Out(1, 1, text);      // Print text to LCD, 2nd row, 1st column
     WordToStr( x, txt);
     Lcd_Out(2, 1, txt);
     x=0;
  //  delay_ms(300);
//    Lcd_Cmd(Lcd_CLEAR);
//    Lcd_Out(1, 1, text);
//////////////////////////////////////////6
 mmccommand(){
 char i=0;
char retry=0;
r2=1;
while (i<10)
{spitransferbyte(0xff);
i++;
i=0;
portd.f1=0;
spitransferbyte(0x40);
spitransferbyte(0x00);
spitransferbyte(0x95);
while ((r1=spitransferbyte(0xff)) == 0xff){
retry ++ ;
if (retry>8) break;
x=r1;
portd.f1=1;
lcd();
/////////////////////////////////////////////0
void main() {
                  // PORTB is output
  Lcd_Init(&PORTB);         // Initialize LCD connected to PORTB
    pins();
   mmclnit();     // config spi
 mmccommand();
while(1){
Accessing the SPI module through SFRs directly instead of using the mikro C built-in functions is possible, but involves the risk of introducing new problems if you are not familiar with low level PIC programming.
You should at least think about suitable means to verify the correct operation of your code. Personally, I prefer watching the hardware signals with an oscilloscope in this regard.
You are setting mode 0 correctly, but your spitransferbyte() function doesn't return data because it doesn't read SSPBUF.
You can use BF instead of SSPIF to detect the end of transmission.
Setting GEI and PEI makes no sense for your application, but doesn't harm unless any xxxIE bits are set.
I replaced BF instead of SSPIF (if(SSPSTAT.BF==1) received=SSPBUF;) but still no luck ! I read the datasheet of pic and there is mentioned that just one register is for both read and write. do you have any other idea ?
I'm very sorry because I've never worked with memory cards. I'm just a newbie. So in this case can't help you. :sad: May be you can look for clues in the datasheet.
char txt[6];
char r2=1;
char r1=0;
char bit=0;
char flag1=0;
char debounce = 30;
char count1=0;
void mmclnit()
trisc.f3=0;  // SCK
portc.f3=1;
trisc.f4=1;  // SDI
trisc.f5=0;  // SDO
sspcon1=0b00100010;
INTCON.GIE  = 1;
INTCON.PEIE = 1;
trisd.f1=0;        //CS
portd.f1=1;
 char received =0;
SSPBUF = data;
return received;
void lcd(){
     WordToStr( x, txt);
     Lcd_Out(2, 1, txt);
     x=0;
  //  delay_ms(300);
 mmccommand(){
 char i=0;
char retry=0;
r2=1;
while (i<10)
i++;
i=0;
portd.f1=0;
retry ++ ;
if (retry>8) break;
x=r1;
portd.f1=1;
lcd();
void main() {
                  // PORTB is output
    pins();
 mmccommand();
while(1){
Wait, did you switch from AVR to PIC at some point?
Hi every body
I am still challenging with a tiny SD card and I didn’t achieved any success yet ! I found that It doesn’t need to write a SPI function myself to work with a SD card, and after two weeks, I came back to the first start point. I am using these codes:
unsigned short take, buffer;
char r1;
void main() {
  trisd.f1=0;              //CS
  portd.f1=1;
Spi_Init_Advanced(MASTER_OSC_DIV64, DATA_SAMPLE_MIDDLE, CLK_IDLE_LOW, LOW_2_HIGH);
while(1)
delay_ms(1);
portd.f1=1;
r1=0;
while(r1<10) {
spi_write(255);    // write dummy for going to SPI mode
r1++;
portd.f1=0;
spi_write(64);    //cmd0
spi_write(0);     //argument
spi_write(149);   //crc valid only for mmc_go_idle_state
delay_ms(1);
take=spi_read(buffer);
portd.f1=1;
and I connected the SCK, SDI and SDO pins of PIC to the oscilloscope but I didn’t receive any pulse from SD, as you know according SD data sheet , after sending those Coeds I should receive “1” that means card has gone to the idle mode , but unfortunately the card don’t reply !!!!!!!!!!!! I am so confusing, Does any body have any idea ? I formatted the card once fat16 and once fat32 but the card didn’t reply .
Your latest code doesn't include waiting for a card response.
You need to wait 8 read cycles, as in your previous code, see post #26.
yes I know, I try to make this waiting time by 1ms delay in my codes. also I wrote this command "spi_read(buffer)" 8 times following each other to wait 8 read cycles, but still I didn't receive "1" as reply of cmd0 ? why ? do you have any other plan ? by the way I provide a oscilloscope too and I can see what I am sending in the SD card.
If there's no card response, although all involved signals are showing correct waveforms (correct level, correct SPI mode), a hardware problem should be expected.
I can only refer to the code shown in your post. It should comply to the sequence required by the SD-card specification.
The usual implementations are different from your code in several aspects:
- cmd is preceeded by a 0xff byte. If I understand right, this is required by the specification (Ncs = 8 clock cyles)
- no 1 ms delay. It's useless, because the command is only processed, if the clock is continued
- up to 8 instead of 1 reads succeding, stop on a none 0xff answer
- the 8 reads are sending 0xff, probably not required by the specification
could you please give me correct codes ? just for sending CMD0 and receiving 1 as response .
