[SOLVED] How do i count the duplicate number for the last one... (codeblock)
Ashieboy
Member level 1
Malaysia
Code C - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
#include <iostream>
using namespace std;
int x[] = {20, 23, 45, 11, 62, 34, 23, 47, 11, 20, 15, 17, 36, 29, 30, 23, 14, 56, 20, 11, 62, 11};
int main(){
int t=22,count;
cout<<"Total number in the array is " <<t<<endl;
int  highest, smallest;
highest=x[0];
for (count=1; count<t; count++){
if (x[count]>highest)
 highest=x[count]; }
 cout<<"The highest number is "<<highest<<endl;
smallest=x[0];
if (x[count]<smallest)
 smallest=x[count]; }
 cout <<"The smallest number is "<<smallest<<endl;
int average=0,a;
float d=22,sum;
for (a=0; a<22; a++){
average+=x[a];}
sum=(average/d);
cout<<"Average of all the numbers in the array is "<<sum<<endl;
cout<<"\nNumbers in the array that is duplicated"<<endl;
int k=0, l, m, n=0, p=0;
int h;
for (int i=1; i<t; i++)
    bool matching = false;
    for (int j=0; (j<i) && (matching == false); j++)
        if (x[i] == x[j]) matching = true;
        if (!matching) cout<<x[i]<<"="<<endl;
    l=x[k];
    while (p<t)
        m=x[p];
        if (l==m)
            n=n+1;
        p++;
    k++;
    p=0;
    n=0;
assuming you are counting the occurances of a value in the array - something along the lines of?
for (int i=0; i<t; i++)
if (!matching)
    int count=1;
    cout<<x[i]<<"=";
    for(int k=i+1; k<t; k++)
        if(x[i]==x[k]) count++;
    cout << count << endl;
You are certainly not evaluating the bounds of the array; for instance, at line 31 of the code above you are starting evaluation from 1, not 0. The same at line 10.
oh, thank you horace1 and andre
no wonder 20 r not there I forgot to start from 0. lol.
Another point that don't make any difference at this case, but in order to make the code more self consistent it is advisable you do not manually determine the size of array by constant, but using something like sizeof (int x[]) instead of set it to 22.
when run with CodeBlocks the program
if (!matching)
    int count=1;
    cout<<x[i]<<"=";
gives
Total number in the array is 22
The highest number is 62
The smallest number is 11
Average of all the numbers in the array is 28.1818
20=3
23=3
45=1
11=4
62=2
34=1
47=1
15=1
17=1
36=1
29=1
30=1
14=1
56=1
is there any other way to count duplicate without using "bool"? and how can i only make the cout for duplicate more than 1?
try
if (!matching)
    int count=1;
    if(count>1) cout<<x[i]<<"=" << count << endl;
not sure what you mean by "bool"
oh what i mean by "bool" is the command
if (!matching)
since i only find this method on the internet so i just modify it
just curious if there is more simple method thats all :thinker:
you could replace the duplicates with a number you are not intested in, e.g. INT_MAX
    int count=0;
    if(x[i]!=INT_MAX)
      for(int j=i+1;j<t;j++)
        if (x[i] == x[j])
          count++; x[j]=INT_MAX;
    if(count>0) cout<<x[i]<<"=" << count << endl;
or when you find a duplicate you could delete it from the array
