How can I do GPIO Programming?
HHM
Junior Member level 1
Hi,I have an Android6410(arm11)Board (**broken link removed**).
I dont have any dll for GPIO programming.
I am VB.Net programmer,How can I control GPIO Ports.
Please Tell me How Can I do it?
I am beginner in embedded programming and C++.
As ckshivaram mentioned, look on the CDROM.
You should have a BSP (Board Support Package) for Windows CE 6.0 included on the CDROM.
The company also has a download area:
If all else fails, contact Boardcon for the BSP.
You can download the program from the Official Site of the .
Even you can get whatever you want from the official site about the broad ,you may have a try.
Reading the broad's handbook will help you get fimiliar with the broad .And here I recommand a book---C++ Primer,which is a very popular with the beginner of C++.
That may be useful for you.
Reactions: HHM
    HHM
You will have to create drivers for that and call that drivers from the Application program. I had the same problem. I had a SBC6410 board (from Boardcon) and had WinCE installed in it. After weeks of searching, I found that I had to create stream drivers that can access Hardware Registers of the processor and ultimately, can control the GPIO pins. I have developed drivers for WinCE OS. Here, I have attached the files for drivers. To read more about how to make this and use it, go here :
Windows CE: Using a Driver to Read/Write Hardware Registers
And one other thing, This drivers are for Samsung's S3C6410 processor
  • GPIOdrv.rar
Reactions: HHM
    HHM
Hi,Thanks for your attention,
Please Tell me Whats is Your DRIVER Develpment IDE's Name.
How Can I compile this Example?
I used Microsoft Visual Studio as IDE. To compile the driver code, I included it with source code of the WinCE OS and then compiled the OS. And when I loaded the image generated by the compile build, it created a .dll file in the device.
We are planning to buy a development board for educational purposes (price do not exceed US$ 200).
Can anyone suggest which board of the following two is better?
1- SBC6410 Single board computers : **broken link removed**
2- S3C2440 ARM9 BOARD MINI2440 MIT 7" LCD&TOUCH PANEL 256MB:
Or if there is another third board, kindly advice
Thanks & Regards
