S
sick_man
hahahahah
the solution is staring me in the face
up convert the dtmf to 6khz
simply add a 1khz modulation tone am using a small audio mixer to the transmited signal
then on the other end filter it out to leave the data
using a pll locked to the removed 1khz tone {this should deviate at 1hz}
adding a further referance tone will give a higher order correction factor so the bandwidth can be increased
this way defeating the silence periods
problem solved
problem solved
