[PIC] Home Automation GSM system with PIC16f877a
well thanks... yeah I am also going for this modem. But from a UK supplier. :)
Thanx.. Yeah I am just about to start my programming in C++. I am not sure of using labview because didn't use it before. I will use a compiler such as IAR embedded work bench
in which I will program.
I am working on GSM modem TC35i Siemens... with PIC16f877a... programming the code as I learned from some sample projects..but still didnt get any output.. here is something what it looks like:
// Author : CYTRON
// Project : SK40C GSM
// Project description : GSM Enabled Smart Home.
// This sample source code is valid for
// 20MHz crystal.
// include
#include <pic.h>
#include <string.h>
// function prototype (every function must have a function prototype)
void delay(unsigned long data);
void send_config(unsigned char data);
void send_char(unsigned char data);
void lcd_goto(unsigned char data);
void lcd_clr(void);
void send_string(const char *s);
unsigned char uart_rec(void); //receive uart value
void uart_send(unsigned char data);
void uart_str(const char *s);
void gsm_send_command(const char *command);
void gsm_read_line(char *buffer);
// global variable
char gsm_response[20];
char command[10];
// main function (main fucntion of the program)
void main()
char read_sms_command[] = "AT+CMGR=1";
char delete_sms_command[] = "AT+CMGD=1";
//set I/O input output
TRISB = 0b00000011; //configure PORTB I/O direction
TRISD = 0b00000000; //configure PORTD I/O direction
TRISA = 0b00000111; //configure PORTA I/O direction
LED1=0; // OFF LED1
LED2=0; // OFF LED2
//Configure UART
SPBRG=10; //set baud rate as 115200 baud
BRGH=1; //baud rate high speed option
TXEN=1; //enable transmission
TX9 =0; //8-bit transmission
RX9 =0; //8-bit reception
CREN=1; //enable reception
SPEN=1; //enable serial port
//setup ADC
ADCON1 = 0b00000110; //set ADx pin digital I/O
//display startup message
lcd_clr(); //clear lcd
send_string("Cytron Tech."); //display "Cytron Tech."
lcd_goto(20); //set the lcd cursor to location 20
send_string("Smart Home"); //display "Smart Home"
// Delay for a while.
delay(100000);
// Clear the LCD and display the new message.
lcd_clr();
send_string("Testing Com...");
// Make sure we can communicate with the GSM modem.
gsm_send_command("AT");
// Read the response.
gsm_read_line(&gsm_response);
// We should receive "OK" from the GSM modem.
// If we don't, display "Error".
if (memcmp("OK", &gsm_response, 2) != 0)
lcd_clr();
send_string("Error...");
while(1);
lcd_clr();
send_string("Waiting for");
lcd_goto(20);
send_string("Call Ready");
// Waiting for the GSM modem to search for the network.
// We will receive a blank line before receiving "Call Ready".
// We should receive "Call Ready" from the GSM modem.
if (memcmp("Call Ready", &gsm_response, 10) != 0)
lcd_clr();
while(1);
lcd_clr();
send_string("Setting Text");
lcd_goto(20);
send_string("Mode...");
// Set text mode for SMS.
gsm_send_command("AT+CMGF=1");
// Read the "OK".
lcd_clr();
send_string("Ready");
while(1)
// Check whether there is new data from the GSM modem.
if (RCIF == 1)
// Check is there a new SMS?
if (memcmp("+CMTI: \"SM\",", &gsm_response, 12) == 0)
// Get the SMS index.
// The command array is already initialized as "AT+CMGR=1" and "AT+CMGD=1",
// we need to changed the index to the actual one.
read_sms_command[8] = gsm_response[12];
delete_sms_command[8] = gsm_response[12];
lcd_clr();
send_string("Reading SMS...");
// Send command to read the SMS.
gsm_send_command(&read_sms_command);
// The first line is the SMS info which we don't need.
// We only need the second line which is the message content.
gsm_read_line(&command);
// Read the newline and "OK".
// Switch on the light if we received "on".
if (memcmp("on", &command, 2) == 0)
LED1 = 1;
LED2 = 1;
// Switch off the light if we received "off".
else if (memcmp("off", &command, 3) == 0)
LED1 = 0;
LED2 = 0;
// Send command to delete the SMS.
gsm_send_command(&delete_sms_command);
// Read the "OK".
lcd_clr();
send_string("Ready...");
// functions
void delay(unsigned long data) //delay function, the delay time
{ //depend on the given value
for( ;data>0;data--);
void send_config(unsigned char data) //send lcd configuration
rs=0; //set lcd to configuration mode
lcd_data=data; //lcd data port = data
e=1; //pulse e to confirm the data
delay(50);
e=0;
delay(50);
void send_char(unsigned char data) //send lcd character
rs=1; //set lcd to display mode
delay(10);
e=0;
delay(10);
void lcd_goto(unsigned char data) //set the location of the lcd cursor
{ //if the given value is (0-15) the
if(data<16) //cursor will be at the upper line
{ //if the given value is (20-35) the
send_config(0x80+data); //cursor will be at the lower line
} //location of the lcd cursor(2X16):
else // -----------------------------------------------------
{ // | |00|01|02|03|04|05|06|07|08|09|10|11|12|13|14|15| |
data=data-20; // | |20|21|22|23|24|25|26|27|28|29|30|31|32|33|34|35| |
send_config(0xc0+data); // -----------------------------------------------------
void lcd_clr(void) //clear the lcd
send_config(0x01);
delay(600);
void send_string(const char *s) //send a string to display in the lcd
while (s && *s)send_char (*s++);
unsigned char uart_rec(void) //receive uart value
unsigned char rec_data;
while(RCIF==0); //wait for data
rec_data = RCREG;
return rec_data; //return the data received
while(TXIF==0); //only send the new data after
TXREG=data; //the previous data finish sent
while(*s)uart_send(*s++);
while (*command != 0)
uart_send(*command++); // Send the AT command.
rec_data = uart_rec(); // Read the echo.
// Send <ENTER>.
uart_str("\r\n");
// Read the echo until Line Feed character is received.
do {
} while (rec_data != '\n');
// Read the data until Line Feed character is received.
do {
*buffer++ = rec_data;
let me know how the ADCON1 works.. and how am I going to receive a message into controller? I think the strings go in the buffer as shown.. and it can then be controlled for LEDs. What I want is my code to be clear and concise... this is something little mixed up. It will be very helpful for any kind of assistance. Thank you in advance
