high speed 4-input analog switch circuit needed
chickenvlsi
Newbie level 6
Newbie level 6
Hi All,
I am a newbie in analog circuit design.
The thing is that I am responsible for designing a high speed 4-input analog multiplexer ( which is also called as 4-input switch). However, I could not find any basic paper about it.
Could you please recommend me some basic papers about high speed analog multiplexer?
Actually, I tried with IEEE explored but failed to find.
Thank you very much.
Some people consider 1 MHz as high speed, others 10 GHz. The difference actually matters in circuit design.
Also signal level, source impedance, distortion and crosstalk requirements.
The switch that I have to design works with 4GHz clock.
Could you please recommend some basic documents about it?
Thanks very much
Do you mean 4 GHz signal or 4 GHz switching speed?
Personally, I don't know literature, the topic is too far from my work.
HEF4053B just check out the data sheet of MUX.. and are you using a binary switch ?
