mtwieg
Advanced Member level 6
- Joined
- Jan 20, 2011
- Messages
- 3,919
- Helped
- 1,311
- Reputation
- 2,628
- Reaction score
- 1,443
- Trophy points
- 1,393
- Activity points
- 30,134
Depends on the MOSFETs. The right FETs can handle 4KVA. As bradtherad states, drawing 4KW from 48V without large power losses requires heavy wiring, but it's certainly possible.ok, so i decided for 2KVA inverter, with power mosfets switching at 50KHZ, is it any practicable now ?????? 48v bank input ??????
No way to tell without looking at the specific VFD. Most VFDs will have their own rectifier circuitry for creating the DC bus voltage, so you'll have to disconnect that. But one thing to worry about is the controller for the VFD. It might now make it easy to integrate your own DC-DC converter with it, especially if it uses one controller for both its rectification stage and inverter stage. In the worst case you may have to make your own controller for the inverter, but that shouldn't be too bad.what modification i need to do with DC VFD ac motor drives????
