muddasirwaheedmalik
Junior Member level 2
- Joined
- Jul 3, 2012
- Messages
- 23
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,281
- Activity points
- 1,535
Let me just clarify what you're suggesting. You want to convert 48V to >310V (as picgak points out) with an isolated high frequency SMPS. Then you will invert the 310VDC into 220VAC with some sort of PWM. Correct?Him I intend to design a two step (square wave ) at the moment, inverter. power target 4KVA, input 48v DC, switching module fuji BJT 500A/2.5 KW in pairs or EUPEC 11.kW IGBT.
But the transformer and current requirements are very steep for such a load, so i intend to make an intermediate stage inverter at say 50KHZ using a much smaller EI core ferrite transformer converting 48V dc to 110 or 220V . rectify it using high power high speed diode modules some filter caps and then then switch it with power module from 110v/220v dc to 220v ac.
Reason. its more complex, more components and costly, BUT, would i be saving on the 4kva transformer which would now be requiring lesser guage wires 20 AMPS on both primary and secondary at 4KW as compared to 100Amps on primary side if i were to switch from 48v Dc ????? any suggestions????
efficiency. You should definitely use MOSFETs for the DC-DC converter part,
Hi againI intend to make a pull push type inverter at this stage using IGBT.
I think you're referring to the DC-DC converter stage, which isn't an "inverter." For the DC-DC stage, a push pull could work, but isn't really optimal. A half or full bridge stage would perform better and require a slightly smaller transformer (but they are somewhat more complicated). Again, I recommend using MOSFETs for this stage.Can u please give me some schematic/idea. as i want to proceed is to make 48vdc to 310V DC, i have ferrite EI core 4KW transformer, for 50KHz switching speed and 100A ultra fast rectiifer 100A. I intend to make a pull push type inverter at this stage using IGBT.
Typically you use a PWM full bridge to drive a lowpass filter directly.Now when i have 310 v dc, what would be design to convert it to 220V ac without transformer. ???
Yes, push pull for the DC-DC stage will be simpler circuitry than a half bridge or full bridge, but push pull will require power components with higher ratings. Either way can work, it's just a tradeoff between complexity/performance/cost.H bridge would be complicated, i have PCB/kits modules for square wave generators/controllers, now i just want it to oscillate at higher frequency and using MOSFETS and using significantly lower size ferrrite core i can switch it to 1:8 step up converter to get around 320V, rectified and then use the "requested" filter design to generate modified sine wave without output transformer.????
I wouldn't be so sure about this... do you have the datasheet or part number for the IGBTs? IGBTs generally aren't too good for low voltage, medium current operation, due to their high saturation voltage. With IGBTs, the conduction loss alone will probably be around 7% of the input power. And very large IGBTs often don't work well at high switching frequencies. At 50KHz, I be the switching losses will be greater than the conduction losses. Properly selected MOSFETs would actually be much more efficient.As i mentioned i have the high power components for the pull push stage, EUPEC IGBT module which has a 1800A IC continous with 11.5KW Pd, at 25oC, now at 50oC i assume i wouldnot be loading the IGBTs for pull push duty for 4.8KVA , i.e. 4.8KVA/48 volt = 100Amps max , with switched the Pd will be even lower and donot assume them to run any hotter and very efficiennt, since i would be using around 50KHZ switching frequency the EI ferrite would be significantly smaller.
Yes, but for high frequency and high efficiency you need to use MOSFETs for the push pull.4KVA but very high efficiency, Question, can i use high frequny pull push conversion for dc 320V
Yes, so long as the VFD/inverter has similar ratings to what you want, then it will probably be usable. Or at the very least you can strip some useful components out of it. Personally I love tearing apart surplus motor drives in order to get the nice high power components.and then use any industrial type motor controller single phase setting frequency to 60HZ and output to 220VAC, i assume they also accept DC input, i am asking becasue in a flea market here i have seen many 5KVA Variable speed/frequecny inverters at very cheap prices. just a thought ???
