bmandl
Full Member level 4
I think I came to a solution. I will use current mirror with aditional bypass transistor, which can whitstand 6A of current in case, no string is connected, so all the current passes throuhgh this transistor. I draw a circuit in LTspice and simulated it and it works. Please, ignore part values, because they are just for a test. Do you think this will work as expected?
