Jester
Full Member level 6
I'm looking for an Op amp scaling circuit that would convert a +/- 35Vdc signal to the input requirements of a Maxim 11208 20bit A/D (0-3V). The input impedance should be 10M or greater. Accuracy goal is +/-1mV or better
The MAX11208 will be powered from 3.3Vdc
Can someone suggest an appropriate OP Amp and circuit to scale this signal.
https://datasheets.maximintegrated.com/en/ds/MAX11208.pdf
I'm not married to this particular A/D, if there is a better choice available. This part was chosen for the following reasons:
One downside is the need for an external reference, that will add a bit to the cost.
- Sigma-Delta will simplify software filtering requirements
- 2 wire interface that is easier to optically isolate than I2C
- Low cost
