gauravkothari23
Advanced Member level 2
Hi all.
I need to generate high frequency output maxing 60 Khz using 8051 microcontroller.
attached circuit diagram.
Software is not a problem, i would be using timer to generate high frequency.
but as per the circuit diagram, is the components selection perfect..?. will the mosfet work at frequency of 60 Khz. or can anyone recommend me some other mosfets where i can get a better performance.
I need to generate a square wave and drive a inductive load at 12V at high frequency.
