High frequecy edge slowing for 22MHZ
umesh49
Full Member level 4
Detroit USA
I am trying to slow down the edge of 22MHZ clock and searching for appropriate solution.
I want to convert this clock to almost a triangular waveform without effecting my DC levels. it is 0 - 3.3V waveform. Using capacitor is adding a DC offset in my waveform. I would appreciate any suggestion.
Thanks in Advance;
Umesh
That's not plausible and demands at least for detail explanation.
"Adding a capacitor" is rather vague. You can form a low-pass with the output impedance of the clock driver (what is it?) by a connecting a parallel capacitor. It would primarly cause a symmetrical waveform modification, unless the clock driver is very asymmetrical, e.g. a TTL output.
Generally RC or RLC low-pass filters are an appropriate means to "slow down" clock edges. You'll hardly get a triangle waveform with passive wave shaping circuits, rather exponential or gaussian pulse waveforms.
Adding a fixed resistor> ESR of the driver will give more linear results.
( typ 25 ohms for ALCV2@3.3V) and reduce the variation in ESR for logic 1 vs 0. which causes the shift in DC or average voltage for a 50% duty cycle signal.
