kak111
TPS53355
High-Efficiency 30-A Synchronous Buck Converter with Eco-modeâ„¢
TPS53355 is a D-CAPâ„¢ mode, 30-A synchronous switcher with integrated MOSFETs.
It is designed for ease of use, low external component count, and space-conscious power systems.
This device features 5 mΩ/2.0 mΩ integrated MOSFETs, accurate 1%, 0.6-V reference, and
integrated boost switch. A sample of competitive features include: 3-V to 15-V wide conversion input voltage range,
very low external component count, D-CAPâ„¢ mode control for super fast transient, auto-skip mode operation,
internal soft-start control, selectable frequency, and no need for compensation.
The conversion input voltage ranges from 3 V to 15 V, the supply voltage range is
from 4.5 V to 25 V, and the output voltage range is from 0.
The device is available in 5 mm x 6 mm, 22-pin QFN package
https://www.ti.com/lit/ds/symlink/tps53355.pdf
