jian
Advanced Member level 3
- Joined
- Sep 8, 2003
- Messages
- 858
- Helped
- 176
- Reputation
- 352
- Reaction score
- 21
- Trophy points
- 1,298
- Activity points
- 9,433
Hi, Ramani:
By isolate them, I mean "insulate" them. There is no way to isolate them electrically because there will be field between. However, you use a substrate of 10 ohm.cm and it is semi-conductor (SI). You need to have a low loss dielectrics with little loss between the SI and your metallic strip. It should reduce most of the loss immediately. Best regards.
