HFSS Tutorial for transmission line vias
HFSS Tutorial
Hi!
I am new user for HFSS. I want to know that does any example simulation for Mobile Phone antenna (HFSS)
Please email me directly:huliang375@126.com
Thanks!
HFSS Tutorial
hI, i'm a new user of HFSS, i need to model and design ans make a simulation to a metamaterials, extract the refractive index from S parameeters, if some body can help me here is my e-mail qarchia@yahoo.fr thanks a lot
Re: HFSS Tutorial
plz anybody help me ..............
In HFSS i know how to design rectangular microstrip patch antenna for one element , i need any tutorial to make 4*1 array.
plz plz help me
thanks
HFSS Tutorial
William_cao> the IC Package / simulator isn't an ability of HFSS. You should use SIwave.
Edit: and a question for me...
A friend asked me :
"ok, here's your antenna structure.
Now, tell me, if I inject a 30V modulated signal here, at the feed point, what's happening?"
Here's a picture of the located problem:
The image contains 2 pictures:
- on the left, a inverted color of the structure, where my friend wanted me to put the voltage
- on the right, the normal color structure
I told him I cannot define a voltage port, in my structure.
Because the voltage port is defined for a surface, and the place he wanted me to put a voltage port is a volume (between 2 conductors, located by the red arrow).
My questions are:
- is it possible, in HFSS, to define a voltage port between 2 points from 2 different object, so not in the same surface ?
- does this makes a sense ???
Thanks a lot for your help !
Edit: apparently, if I "activate" surface#1 and surface#2, then I'm able to define a voltage between 2 surfaces. It's still calculating, but I don't have a clue if it'll converge or not...
Edit2: it does not converge at all.
So, let's turn to a lumped port... SOUNDS GOOD, it's working :)
HFSS Tutorial
Hi , I would like to know if somebody could send me the preinstalled CST microwave exemples , because they are missing in my C:\Program Files\CST STUDIO SUITE 2006\Examples\CST MICROWAVE STUDIO\Transient Analysis\Antennas folder.
I would like to use it to make a simulation about the microwaves effects on the Human brain .
Many thanks
Re: HFSS Tutorial
You have posted in the wrong thread. The name of this thread is "HFSS Tutorial".
Re: HFSS Tutorial
Can anyone post the examples of analyzing Frequency selective surfaces using HFSS
Hi;
please can you help me I need HFSS software to used in the waveguide simulatioin
Added after 1 minutes:
hi ;
Ineed HFSS software.exe my email:elafandimounkid@gmail.com
Thank's in advance
Hey... any body could help in assigning exact boundaries, exicitation in HFSS for Linear array design..... Whenever i change any exicitation method or dimension of boundaries(Vacuum material) , an unexpected drastic change in 3D pattern.. Is there any specification in assigning exicitation and boundaries......... please help me......
Re: hfss tutorial rf mems
how can i design mems switch using hfss?
plz post me the result as well as tutorial.
if possible plz mail me at harmeet420@gmail.com
Added after 48 minutes:
plz send me the tutorial and result of rf mems switch
plzzzzzzzzzzz help me
hi everyone thanks for the tutorials :) alot of them helped me with microstrip patch antenna...but i was wondering....does anyone have any tutorials on Linear and Planar array antenna? :)
Re: dipole tutorial + hfss
hi,
i have many tutorials related to antenna design in hfss. if some body needs a specific one,do tell me.
thanks
hi,
do you have any tutorial example for stripline ring resonator filter?
i am trying to design a simple 0ne port ring resonator filter using suspended stripline but my design seems incorrect because i keep on obtaining very low return loss (seems like all my signal reflected). I am new in this and really need some guide.
thanks!
