RFgirl said:Hi all,
Just came across this forum, and it definitely sounds heated up with respect to Sievenpiper's work and the dispersion diagram! I've found a dosument on ansoft's website that guides you to plot the 2D and 1D dispersion diagram (would like to share it here, except, am not too sure whether this is allowed, can somebody tell me if i can upload it here?)
Anyways, my main aim when plotting the 2D dispersion diagram is to find the eigenfrequencies of the high symmetry points (gamma, X and M). These values, along with the Bloch impedance will let me extract the inductance and capacitance values (LL, CL, LR, CR). My question is, does anyone have an idea about plotting the Bloch impedance? I've found a book on metamaterials that says that, the bloch impedance can be found by the formula ZB=2P/I*I, where P can be found from surface interation of E and H field of the port surface. This is in essence how the caracteristic impedance Zo is calculated on HFSS, using Zpi.
Does this mean I need to do the simulation in modal mode, and construct a port at the unit cell? If so, what's a good port size, since varying the port size will vary the terminal impedance. And, am i doing this correctly?? Please help!
Thanks alot!
