[PIC] help with MPLAb, including ICD2
No, that doesn't work at all, first it says, new serial USB cable found, when trying to install it, the pc have physical dumb...
Well two things you might try, first load in the application program PicPro form that disc, start the program up and plug in the programmer.... what happens ?
Also open up windows Device Manager and see if anything else is showing up in the Serial or USB devices relating to the FT232 or if it has a yellow ! icon against it.
please tell me if this product is fine, and recommended to buy (+10$ over the old unknown version):
Help is available for such a product?
also, can I operate it on Windows8?
I would recommend avoiding all ICD2 clones, especially concerning future compatibility.
The genuine Microchip ICD2 is NOT compatible with the newer MPLABX IDE, therefore neither are the clones.
I have upgraded all my ICD2s to ICD3s as a result of this incompatibility.
The following programmer/debuggers are compatible with the newer MPLABX IDE:
PICkit2
PICkit3
ICD3
RealICE
Considering Microchip is steadily phasing MPLAB out and if your system is running Windows 8 as an OS, you would be well advised to purchase one of the programmer/debuggers listed above or a compatible high quality clone.
BigDog
hello,
@bigdogguru
I have spent few dollars, and got this:
correct device? is it familiar with you?
i will install it, and post any occuring error
thanks
too bad i saw your last post after I bought it lol
:shock:
You probably could have bought a genuine Microchip PICkit2 for what you paid for it.
Return it.
And buy a PICkit2.
BigDog
