BigBoss
Advanced Member level 7
No.
The outputs of a 741 opamp are very lossy emitter-followers. The datasheet shows a maximum 5V output voltage loss.
There is no -4.5V, it is a 9V battery. All the inputs are the 9V battery divided to produce +4.5V. Then the 741 opamps have a supply that is 0V and +9V.
With a 5V output voltage loss the output will be stuck at +4.5V and will not move. If the output of the opamp can swing with a 3V loss then it can go high to +6V and low to +3V. But then the output of the transistor emitter-followers will only barely swing high to +5.3V and low to +3.7V. The motor will get only 1.6V.
Output of LM741 has AB-Class Output stage, not a emitter follower.If you check the data sheet carefully, you will see that the OPAMP can work dual symmetric power supply.
https://www.ti.com/lit/ds/symlink/lm741.pdf
Otherwise principally it does not make sense to use this OPAMP.If the output stage was a simple emitter follower, you could not obtain a proper voltage headroom but it is not.
Output must be zero volt when any signal is not applied otherwise iif the output stage was a emitter follower there should have been a off-set voltage.
