usama14
Member level 5
- Joined
- Oct 31, 2015
- Messages
- 90
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 6
- Activity points
- 756
Can you provide more information on the topology you are planning to use?
Also I want to know that if the actual inductance falls short of the required inductance, then what would be the outcome?
Thankyou in advance.
At 100 kHz flux max density should be limited to 150 mT to keep core losses under control.
Working with Vin_min = 45 V and Vin_max = 48 V gives;
Np = 2
Ns =15
Inductance(p) = 21 uH
Peak Ip = 28.5 A
Core loss ≈ 11 W
It appears your transformer design will allow for Vin_min = 38 V and a low peak flux of 80 mT.
So it is a very conservative design that will run cool with only about 1 W of core losses.
Peak primary current will be about 29 A and average operating current 22.6 A.
BradTheRad, Wouldn't the secondary of 7.8 mH be the worst case for 100 KHZ, compared to the 95 uH primary?
Np = 2
Ns =15
Peak Ip = 28.5 A
Core loss ≈ 11 W
Smaller inductance admits greater current within a given time. You can expect to adjust switching frequency, to obtain desired performance.
Since I like to watch current bundles go round loops, here's a simple simulation of your transformer with 48V square waves.
From my (theoretical) experiments with transformer primary Henry values, it appears they can occupy a wide range and still perform efficiently.
So the design parameters are okay in your opinion then?
It should work just fine according to the specifications.
I had a similar question though. Actually I made another transformer, but it has low primary inductance value due to the breakage of the core. And by changing the duty cycle value, Im not getting a significant change in the output voltage. Is it that the transformer is getting saturated or something? Or is it bcz of the inductance values?
It is impossible to give a useful opinion without the actual transformer specifications.
Let's see a theoretical comparison. Add a transformer with 1/2 the primary value, and another with twice the primary Henry value.
Differences are slight. Again, this is only theory.
The lesser primary value has a rising waveform and it will draw greater current. If that peak draw goes above saturation level, then it would cause deteriorated output.
Deteriorated output? What does that mean?
I wrote:
You can send very high A through the inductor, but the flux field only reaches a certain intensity (saturation level), and then does not rise further. Then as soon as you start to draw current from the inductor, the A you get is less than the previous A you fed it. Therefore you do not get back all the energy you put in. That is the deterioration I referred to.
So does this relate to the non-changing output when the Duty Cycle is changed? Actually the output changes in stages of 5V when the duty cycle is changed by 5% for the 2k ohm resistor. But as soon as the load is increased, the output remains constant at 148V dc. That's where I'm all stuck right now. :/
From what the other replies state, your transformer should operate okay and not saturate. I hope I did not appear to talk as though I was contradicting the other replies (or your factory specs).
There is a different problem which is likely to pop up, namely parasitic resistance. This can appear in several places, and it will hamper your power transfer. To cure it:
* Every switching device has to be biased sufficiently so it presents minimum resistance.
* Every wire connector must be attached securely. All contact surfaces need to be clean and shiny.
* Your power source needs to have very little internal resistance.
All this adds up to, is you need to make sure you can get 48V 21A going through your transformer.
There is no information about the leakage inductance, at 100kHz, XL = 2.pi.F.L this inductive reactance limits the amount of power the transformer can let thru, as you load the Tx more and more the Vout will drop due to winding R and total leakage (Il x XL)... having a simple HV sec over a LV primary will give 4x the leakage than for splitting the HV sec and putting either side of the LV primary.
p.s. you can measure the Lleak by shorting the LV side (properly) and then measure the inductance from 16-17 to 22-23, this gives the total leakage referred to the HV side.
