Help on Inter Task Communication
vijay s
Full Member level 3
Coimbatore, India
Hi Folks
I'm a Newbie in RTOS. I need help in using Inter Task Communication. i'm using ucOS for my code.
I need to communicate Speed Calculated from Speedo Task to Display Task. I don't like to use shared Memory here. what ITC Tool i can use for Communication between above mentioned Task?
It would be a better help, if someone can share an example where to use different Inter Task Communication Tool.
Thanks in Advance....
hi vijay
there are many mechanisms in Inter Task Communication...You can use any one based on your requirement..Please follow this documents..they may be use full to you..
And also once check Begging LINUX Programming book..You will find lot of example programs on Inter Task Communication
  • itc.pdf
  • RTOS Part2.pdf
