yes, you could send your nellist to me, I'll help you.France said:Could you teaches me how to do crystal OSC tran analysis.
Hi ysz
Your circuit, is right?
thx.
Tahnks for you explanation. I'm a new guy in crystal oscillator design and i'm quite interest in crystal models generation. How can i generate crystal models? Test there Z-f curves and using software to generate RLC models?crystalguy said:Teddy,
i am afriad there is no library out there that i know of. it is a tedious task generating the models and (as i said) the device models are highly dependant on the manufacturer and the the package. one of the reasons manufacturers are hesitant to provide models is because of the way crystal are spec'd. an example would be that the model may show the R1 value to be around 7 or 9 ohms and this would well represent this value AT 100uW that is spec'd. the maunfacturer spec sheet, however, will say something like "90ohms max". Part of the problem is the fact that these models are really a comforting fiction (albiet, a useful one) that overlooks the rather non-linear behavior of these devices. The unfortunate reality is that at very low current (like the moment of startup) the R1 value may be many times higher dropping down rapidly as the current increases, than going back up as the part is overdriven. Visualize a broad U shaped curve ploting Y=R1, X=crystal power.
France said:Humungus said:There are some books on crystal oscillators in the e-book forum
Could you poost e-book wed for me reference?
tlihu said:I was simulating the circuit posted by ysz. It does oscillate with the desired freq, however the amplitude is quite small, i.e., a few uV. Is this correct?
I am puzzled on the oscillator designandy2000a said:1. use need 48M Xtal spice R-L-C model ..
2. use AC sim check invert + Xtal have 180 degree phase shift
and frequency = Xtal freq
3. check invert gain
4. close loop use .tran and you must be use hspice .option
method=gear or trap ..
5. assign a initial voltage let spice sim speed up
6. make sure Xtal can really osc
ps. sometime hspice sim Xtal is work but real ASIC is not ..
you should becareful use .option parameter
