jejeorg
Junior Member level 3
analog test
I' d like to have your answers to a test on analog design that was submitted to me:
1- In a single stage amplifier, increasing the loading capacitor improve or not closed loop stability?
2- In a single stage amplifier, how bias current influence the gain?
3- How to reduce offset in an op amp?
4- To realize a narrow band low noise amp stage is better to use N-channel or P-channel MOS?
5- In a fully differential amp stage, the output voltage swing can higher than supply voltage?
6- How to eliminate rigth half plane zero in a miller compensated amp stage?
7- In a class AB amp stage biased with a current "Ib", how much current can be supplied to the load?
8- What is the minimun supply voltage at which a fully differential amp stage can operate? How input nodes have to be biased?
Please answer without consulting any book, as i did (and if you want, of course)
Enjoy!
jejeorg.
Enjoy!
jejeorg.
