Help me realize a buffer with these specs
benever
Member level 5
Member level 5
how to realize a buffer :
1) the dc voltage follower
2) the hign input resister and the low output resister
3) the ac gain is about 1
Re: buffer
You usually use an Opamp for this. An opamp with unity gain configuration
buffer
where does your design been used?low-power ,high-resolution or high speed?I am sure that have many different consideration.
Re: buffer
we usually use a inverter for this or a repeater.
