I am not sure if I really need a pi L/C filter before the LT1083, I think this is too overkill as most commercial receivers should cope with a little rip. I do not know.
Some one mentioned a centre-tapped Tx sec as a lower rms solution - unfortunately not so, the rms is 70.7% of the full current in each wdg for a centre-tapped output -
Alternately a CT solution in the same space can only carry 50% of that current for a singe sec solution. ( 5^2 x 2 x 2 wdgs = 100W )
Making the 30V secondary 15-0-15 (center tapped) does not increase the winding size.
On an ideal transformer I see the benefit, curious if there still is a benefit on a real transformer.
By the way, I believe that modern transformer technology is excellent to very good
{ foot note: for the same VA out with the same losses, the winding space has to be at least* 50% larger for the centre-tap Tx,
Therefore the cross section of the 10A winding wire will be exactly 1/2 of the cross section for the 5A winding wire.
one case it is 10V at 10A and the other case it is 20V at 5A. 20V is split as 10-0-10 with both halves rated for 5A.
