shenlufei2005
Newbie level 5
Hello everybody!
I am designing a DC-AC Inverter for an EL-Lamp. The DC Input is 12 VDC. And the AC output should be about 120 or 130 VAC at the frequency above 20 KHz. The whole circuit should have a small size lower than 2cm X 4cm, since the EL-Lamp ist about 20 cm2. Because we don't have signal generator with large Outputvoltage like 120 V, or available Amplifier , I have done the Measurement and Characterization of this EL-Lamp by using Keithley sourcemeter, which can provide approximately through programming 100Hz 120 Vrms Sine Wave Output. That means, the modelling of this EL-Lamp is under low frequency. According to the general equavalent circuit of an EL-Lamp, I think it should consume about 1 W Power.
My idea is to use a DC-DC converter to generate about 36 VDC and after that the 36 VDC will be converted to 36 VAC and by using a high ratio transformer, I can transform the 36 VAC to about 180 VAC. Of course, the Waveform is still Rectangular. So use a low pass filter. I may obtain a pure sine wave output voltage with Vrms=130V at frequency above 20 KHz.
However, I cannot find the transformer, which is suitable for this application, namely high frequency, high voltage , reasonable small size.
Can anybody help me? Or has somebody found the mistakes of my design idea? The DC to DC Converter Chip, which I am going to use is MC34063 of On Semiconductor.
Lufei
Lufei
