dsjomo
Full Member level 2
I agree with Mazz's points, including that there are many people lieing in their paper......
I'm not familiar to GPS's specification but a lot of people say it is not so tight as 2G or 3G standard. So if one can simplified, cost-down or make it a low power design, it would be a great job. As everybody knows that single-end mixer is not as good as differential mixer, but if a single-end mixer can fit our need and spec., I think nobody will take diff. mixer to do the same job.
The only problem I can figure out is that single to diff. mixer may needs larger VDD if there is a tail current source underneath. Normally the quad is operated in saturation region(for NMOS) applied with large LO driving signal. The two papers both use resistive load thus they comsume DC voltage headroom. If the voltage constrain is limited in 2V, it is hard to insert an tail-current underneath. O. Shana'a uses a resonent tank to eliminate the need of the tail-current.
Besides, single-end mixer has a large LO to IF feed through compared to diff. mixer, the following filter should have enough P1dB to handle the signal.
