arwen16
Member level 1
We designed a bias network for Cree CG2H40010F for a triple band power amplifier on Rogers substrate (Er=2.2, h=0.787mm). We biased the transistor with the typical values of Vg=-2.6V and Vd=28V. On doing so, we observed a current of 150 mA in the gate and voltage drop in drain the moment we crossed the pinch-off voltage (-3V). We tried something new; a way to eliminate the bypass capacitors. What could be the reason our DC bias network is not working? We have used high SRF resistors and capacitors in the gate bias and stability network. All the components were working (not short circuited). We even tried changing the transistor but we had the same issue.
