amit251291
Member level 1
- Joined
- Jul 18, 2012
- Messages
- 38
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,286
- Activity points
- 1,558
hello tsea,
Its ok, don't be sorry .
I checked it on proteus and it is working well
now there's problem with HARDWARE it seems. Even i think the the same but i found other info on the net, which was posted by some other member. i am posting it here.
This suggests that i should use one more MAX232 but i don't think that i will need it here i am confused.
By the way, special thanks to you I will make sure that your name will be there in my report just let me know your name. i think tsea is your nickname.
MAX232 is line driver chip it convert 5 volt logic into RS232 logic level and vice versa
controller understand the logic of 1 and 0
1 = 5 volt
0 = 0 volt
RS232 standard is
1 = - 6 to 25 volt
0 = + 6 to 25 volt
now you are giving these signals directly to 8051 so 8051 is not able to understand it
now you need one more MAX232 ic that will convert it to 0 and 5 volt logic that 8051 can understand
