gprs modem interface proceduer
wavecom gsm 900/1800 module
Nice library tramp! Do you by any chance sell single unit of SIM300 modules? The inventory page is a bit confusing - it has a price for a single unit but under "package" it says that they come in 100 quantity? (assuming alta-vista translated package correctly :)
Thanks
Thanks bbiandov,
I didnt understand langauge on webpage otherthan engish.I got quotation from a indian distributer for sim300.He quote me $29.5 for 1000 qty.
modulo gsm/gprs benq m22 data sheet
hi
does either M22 or SIM300 have SIM card connector integrated on the module or this is something one must figure out using an external molex for the sim card?
thanks
B
skematik my-g 900/1800
no both modems does not have integrated sim card connectors; you have to add an external one (like Molex 91128)... (do not forget to add also the ESD protection component...)
Hope this helps,
//a
number tx/rx boards in ctu 2 900
Hope this helps,
//a
Hi Andrei,
Could you share where does one purchase the Molex 91128 connector and the ESD part suggested on the SIM300 schematic? I looked around but I can't find a supplier. Only large quantity bulk sellers have those part numbers and of course they would not sell a single item.
Also the spec sheet does not make it clear - are the serial ports TTL-level or are they RS232C level shifted?
Thanks
Boyan
server program sim300
I enquired SIM GSM module few weeks before, Sim 300 $32/pcs base on the 1k quantity.
simple datasheet available on www.sim.com
difference betwen gsm 900 and gsm 1800
If anyone is looking for GSM modules - PM me.
I have SIMCOM SIM100, GM47.
www.simcommunication.com
sell: SIMCOM modules very fast and very cheap! qty 1,5K
my product uses a gsm module
we are manufacturing Fixed Cellular Terminals. We are under immense pressure to use the cheapest GSM module. can anyone tell me whats the cheapest module available in india / china. what is the latest price of sim300?
how to get gsm module
nhczp said:
I try modul SMS/GPRS SIM300 from SIMCOM. It's good modul
Hi nhczp,
Did u used sim300 evalution board or designed its interfacing yourself?did u try its GSM connectivity?
Regards,
tramp
simcom rashmi 300
wclee said:
anyone facing problem using the sim300?
Yes Myself & discussion is continue in topic named SIM300.
EDAboard.com Forum Index -> Professional Hardware and Electronics Design
->Sim300
Regards,
tramp
benq m32 price
I am facing an error while using Sim100S32-E module. I get output somewhat like this.
Step 1:AT+CGDCONT=1,"IP","wap"
OK
Step 2:AT+CSTT = "wap","Telenor","Telenor"
OK
Step 3:AT+CIICR
OK
Step 4:AT+CISFR
ERROR
Step 5:AT+CIPSTART="TCP","www.google.com","80"
ERROR
I have checked data for my service provider. I instructs to not to set any primary and secondary DNS servers but tells to set primary server to 172.18.19.11 and at port 8080. (I got this instruction using my sim in Nokia 6600). But i dont find any AT command to set these parameter. This IP is probably some Proxy server. Any have any idea how to solve this problem?
datasheet benq m22
Hi, Ansib Ali:
I have the similar problem. You mast use AT+CDNSCFG=... An attachment is an example of using AT+CDNSCFG=...
P.S.: Sorry for my bad English :D
what is mean by c/a in gsm 1800
You should use a GSM module of Siemens like MC56, but depends of your application.
If your app is only "data over SMS" then your GSM module should be support only GSM suite (without GPRS if it is possible, I don't know).
But if your app need transfer "data over IP" then you should be adquire only GPRS module. It is no necessary a Module with GSM and GPRS suite.
MC56, G18, G20 are modules with GSM and GPRS suite, then thier cost/ price is more expensive than GPRS module only.
Rgds
what is gsm module in wavecom
Hi guys,
If I want to design a dual SIM card connectors, shall i add a Switching device to select the SIM card to be used? Which parameter shall i use to control ? eg. VSIM?
thanks.
gsm module india price
Searching for interesting projects Based on GSM.
The M2M devices and GSM module manufacturer.
Best regards
Justin
