good conferences and journals for analog integrated circuits
viperpaki007
Full Member level 5
Full Member level 5
Finland
Can any body tell some name of high and mid-level impact factor conferences/journals in field of analog/mixed signal integrated electronics.
Looking forward for the reply.
Hello viperpaki007,
for example look to websites of TEXAS Instruments, ANALOG Devices or LINEAR Technologies.
Register there and then you can use the support and communities for design.
I hope this help you.
Regards
Rainer
I think the most important journal is the IEEE JSSC and its related symposia and conferences (s. at the bottom of this Wiki article).
Unfortunately not cheap, all of them :-(
With very high reputation:
1.) Analog Integrated Circuits and Signal Processing
2.) Circuits, Signals and Signal Processing (CSSP)
Since you are here in the analog and mixed signal design section, This is what my Professor recommends for high quality Journals and conferences when focusing on analog and mixed signal design. It could be different in other peoples opinions.
Conferences if you have working Silicon/measurement results required, in order best to worst, (same numbers mean about = in quality)
1. ISSCC
2. ESSCIRC
3. VLSI sym
3. CICC
4. Asian ISSCC
Journal are
1. JSSC
2. TCAS1
3. TCAS2
Conferences besides top 5 also known as circuits and system (CAS) conferences
1. ISCAS
2. MWSCAS
3.BioCAS
4.NewCAS
Hope this helps,
Jgk
