generation of noise in pspice
vinaiece
Newbie level 6
Newbie level 6
how to generate the noise in pspice ,is thr any circuit to generate the noise in pspice
try taking output from a switching thyristor or some other switching element....
I think this would be easier if you use ADS
In the real life, Zener diodes are usually used as noise generators (see, for example, this app note **broken link removed**). I don’t know if the Zener is modeled with noise in PSpice, but you could give it a try.
I would also like to invite you question to this group, which has some good OrCAD & PSpice experts: **broken link removed**
Do you mean to generate a time domain random signal, with white noise spectrum?
Or do you just want to perform noise analysis?
