Fortran code and LAPACK
MrElec
Tunisia
I've some Fortran codes (*.f90) used to extract eigenvalues and eigenvectors of an impeadnce matrix. These codes should be linked to the LAPACK library but i can't excute them. I'm using Code Blocks as the IDE environment. Can you give me the solution and thanks.
What is the error message produced ?
Do you have LAPACK fortran libraries ?
Did the IDE worked with noerror for simple fortran program?
@srizbf thank you for your response. In fact, i think that i managed to link LAPACK fortran librairies with Code::Blocks. Unfortunately, i'm new to Fortran and when building the code i've obtained a lot of errors. If you don't can you give me your email to send you the files. The codes are very important for me.
The board will help you if you encounter any problem.
There is a message facility through which you can send your requirement.
