danny davis
Banned
1.) When I replace an Logic IC with a NEW Logic IC , there is more problems on the circuit board than before, before had only 2 lights not working, now with the NEW IC those 2 lights that weren't working, work now but i have 5 other lights that aren't working now
It Replaces 2 problems with 5 new problems , what is this called when a circuit board does this?
2.) When I'm troubleshooting a Logic Board and I lift up a resistor leg or an IC logic pins input or output to isolate a stage or branch, The circuits that are in parallel, different channels , branches that are in parallel or in series become FLOATING
What is this called when this happens? is this common for LOGIC circuits? one you lift up an IC pin or component leg it will make the circuit FLOATING? and all the other parallel circuits , channels, branches floating too?
