Z
zenerbjt
Yes i know your situation.
All parameters are changing all the time so how do you calculate anything.
Well.......you fix at a particular position, and calculate for that position.
So take it at mains peak. Take the voltage there as a static case.
So do a flyback converter operating at mains VACrms*(sqrt(2))....Double the output power, and vout same as yours.
..you double the pout as at mains peak, a PFCd flyback is transmitting 2*pout(av)
Hi
Your Flyback design is as attached...this was 10 minutes work.
When you play with the sim you can see whats going on and know how to "mold" the design.
I will send you the LTspice sim of this soon.
LTspice is a free download from linear.com (analog.com)
As discussed, attached is your 220VAC, 36V, 0.5A Flyback PFC attached..in the free LTspice simulator
By the way, the sim is openloop......i didint put the feedback in as the sim takes ages with PFC'd feedback becuase pfc feedback loops are so slow.
I am sure you will be able to put in a error amp with a slow feedback compensator if you want to.
by the way, bpsemi.com chips are in all the led lights sold in uk....but i am pretty sure you cant buy the actual chips in UK, or in Europe or USA(?)
--- Updated ---
Hi
--- Updated ---
--- Updated ---
--- Updated ---
