yonyz
Junior Member level 1
I don't find it not-normal, I just didn't know about it.
I'll try that floating connection, but I remember with 100% certainty, when I first opened these headphones, there was no such thing as a floating connection.
Also, the red and green wires are both connected to the plug properly, I checked that too with the multimeter.
In fact, there's a connection all the way from the plug's ring (the right channel) to the right speaker. Must be a short I guess, so I'll also try switching red and green.
Edit:
Just letting you know, when I take a solder-clean speaker, the working one of the old pair, and check with the multimeter the points where the green and black are connected, there's already a connection, without anything soldered to the speaker. And when I "rub" the probes on those points, the speaker makes noise (like white noise), so I think it has nothing to do with the wires themselves, the speakers themselves are already made like that so those pads are connected.
Edit 2:
Tried floating connection, no sound from both speakers.
Now trying the switch between red and green.
Edit:
Edit 2:
