imran99
Junior Member level 3
Every few years, the standards that are associated with computer peripherals change. For example, the previous CD-Rom standards were upgraded to CD writers, then it became DVD drives and the now, the accepted standard are DVD writers.LCD monitors are the new standard in computer displays. Though they have not yet replaced CRT (cathode ray tube) monitors completely, LCD monitors are fast rising in popularity because of their extremely sleek looks, lower power consumption and more convenient footprint on a desk.
LCD monitors at this point are still quite expensive though and thus, extra care should be given to the unit so that it will maintain its pristine condition.
Probably the most important part that should be taken care of in an LCD monitor is the screen itself. The screen is not as tough as the glass tube of a CRT. If you have an LCD screen you will notice that only a clear, thick plastic separates your fingers from the actual components of the LCD. It is imperative that you take care of your LCD screen as much as possible and prevent it from being scratched.
There is a way though of repairing a scratched LCD screen though that is inexpensive and very easy. All you need is Vaseline petroleum jelly to fill the scratch on the LCD screen. This very simple remedy works because the optical density of Vaseline more closely matches the LCD face compared to air.
All you need to do is to clean the surface of the screen and then take some Vaseline and fill the scratch with it. Gently wipe off the excess Vaseline taking care not to wipe too forcefully so that you leave some inside the scratch.
Also visit the link: ► 2:51► 2:51
How to Fix a scratched LCD Computer Video Display Monitor, LCD TV Screen* - YouTube
