Finding inductance and core loss for a powered iron torroid inductor in an "2TFC" SMPS
****************************________________________**************************************
Would you agree that the following PFC application note calculates the wrong value for core loss?
PFC Application note:
It concerns the equation for calculating B at the top of page 7.
The values for a,b,c,d,e, and x are wrong?
They should be as at page 72 of this below, or am I missing something?
As mentioned before fitting parameters in Magnetics catalogs are often changed between issues. A different parameter set isn't necessarily wrong, as long as it results in a similar loss order of magnitude.
Reactions: zenerbjt
    Z
Thanks, What is the maximum flux density use-able with "Kool Mu" inductors?
Page 9 of the following Mag-Inc powder core catalog says that “kool mu” material has a saturation flux density of 1 Tesla.
So why does the "Kool Mu" B vs H graph on page 48 only show flux densitys up to 550mT?
Maximum "useable" flux density depends on: ability of ckt to handle the lowered Ur, the flux ripple at or about that peak flux, temperature, and the cooling available ...
--- Updated ---
Notice the saturation B = 1.0 Tesla, you may have read the 550 mW/cc @ 100kHz, 1000 Gauss ( 0.1 Tesla ac peak )
--- Updated ---
You can see from the graph, p48 that 1T requires likely more than 1000 A-t / cm - so getting up to high levels of applied H.
--- Updated ---
you can see above for Kool mu at H = 1000 Oe = 79600 A-t / m = 796 A-t/cm, the residual permeability is very low for all grades and the thing is tending towards being an air cored magnetic ...
Reactions: zenerbjt
    Z
Thanks, i see what you mean, from that, i believe we would not want to operate kool mu at much above 100 A.t/cm
Indeed, the -26 grade has only dropped to ~ 82% at 100 Oe ( = H of 7960, = 796.0 A-t/cm ) wheras grade -60 has dropped to ~ 47%
