Fedora Core 6 and IC Design Tools
solution for display :1.0 error baddrawable
i am getting an error message "could not find libXft.so.i" while loading mentor tools.
but the file is present in /usr/lib and is present in the path.
hock
solved by making a link to /usr/bin and put it in the folder /usr/X11R6
x11 backing store rhel5
you should use RHEL4 , there are post here how to successfully install cadence on RHEL.
libstdc++-libc6.1-1.so.2 cent
I am also getting the same Display error,
But i am trying to install IC Flow on fedora 10 and there is no X11R under /usr.
So, please help me regarding to solve the same issue.
linus tool ic design
onee cent of advice.
please use scientific linux or cent os or RHEL if you want to use and of eda tool.
at least you will not get unknown errors..
hock
topped tool for ic design
RHEL 4 is best for Mentor tools, all are working. Use RHEL 4 Update 5.
Re: icstudio cannot connect to display
i am not sure if i understand what you did but what i meant is to
make a symbolic link for the folder "bin" in the "/etc " and put that link in this path "/usr/X11R6" and make sure that that link is named as "bin"
I have the same problem, but in ubuntu (10.04) this folders doesn't exist, can you tell me how make my symbolic link?
May I ask you why Use FC-6???
If you Upgrade to FC-14 Then You may get several Options for EDA jobs, bith proprietary and free.
Tools like Mentor Graphics are only suported by RHEL3, RHEL4
i am running mentor tolls on rhel 5 and rhel 6 with no issues.
mentor supports them on rhel 5. ask your support or just install it and let me know if you get some errors.
hock
I use RHEL 4 Update 5, and will try on rhel 6.
is there any thing new in RHEL 6 which helps using CAD tool?
