Fedora Core 6 and IC Design Tools
ramy_maia
Member level 2
ic design flow with icstudio install
AA
just installed FC6 today it yesterday now
amazed by the gui effects
and i tried the tools on it, Al7amd llah it just took couple of googling to solve the issues and it worked not all the tools worked
- Cadence icms,icfb,..) no problem at all
- Mentor: opening icstudio
1-gave me the error
"libstdc++-libc6.1-1.so.2: cannot load shared object file: No such file or directory"
so i make the link to the file
/usr/lib/libstdc++-3-libc6.2-2-2.10.0.so and rename it as libstdc++- libc6.1-1.so.2 within the same folder
2-then it is opened and gave me a warning (which appeared also on FC4 ) about the disabled backing store, so i enabled it by
open /etc/X11/xorg.conf as a root and insert
Option "backingstore" "true"
Under the Device section.
3-i got another error for Mentor when i try to open Design Architect or IC Statio
// ERROR: Cannot connect to DISPLAY
// Please verify that your DISPLAY (":0.0") is set to a system
// with proper X server authorization. Reference xhost man page.
solved by making a link to /usr/bin and put it in the folder /usr/X11R6 (sure rename the link to be just "bin" instead "link to bin")
Hope it Helps
Happy Ad7a Eid for all
design tool on fedora 10
Hy there. Thanks for sharing.
I tried installing Cadence tools on Fedora 6 a while ago, but didn't work at all. Some compatibility libs were missing, I think. Also, setting LD_ASSUME_KERNEL variable was disturbing the system seriously. Don't know what went wrong...
Now I am trying on a brand new RHEL5 Beta2 - which is based on Fedora 6, but I'm getting X Errors:
Qt Warning: X Error: BadMatch (invalid parameter attributes) 8
Extension: 153 (RENDER)
Minor opcode: 4 (RenderCreatePicture)
Resource id: 0x3f
Major opcode: 1 (X_CreateWindow)
Resource id: 0x3f
Qt Warning: X Error: BadDrawable (invalid Pixmap or Window parameter) 9
Resource id: 0x3c00011
Qt Warning: X Error: BadWindow (invalid Window parameter) 3
Major opcode: 2 (X_ChangeWindowAttributes)
\e Display :0.0 Error "BadMatch (invalid parameter attributes)"
\e request 1 error 8 serial 1407
\e Display :0.0 Error "BadDrawable (invalid Pixmap or Window parameter)"
\e request 153 error 9 serial 1408
Can you help?
Thanks
libstdc++-libc6.1-1.so.2 fedora 10
Cadence Ic design only sopport RHEL 2.1, RHEL 3.0
glibc6 fedora-core-11 permission-denied
If I would have take that for granted, I'd have had still using RH8.0 or worse, 7.2.
Fortunatelly, it seems that with little tweak (or not), many versions of linux supports Cadence, although Cadence doesn't support them...
cadence icfb x11.conf
unfortiantly i don't know a solution for your problem , actually my cadence tools were already installed and i just run them on the newly installed FC6 (i previously installed the tools on an ext3 partition and i mount it whenever i install a new Linux version and i and my TA made some scripts to define some env. variables to get it work)
and i am with you cadence tools works with many ditn.'s even if it is not officially supports them i tried it on FC3,4,6 and Suse 10
tooling core back system design
FC 6 is not good for EDA tools. Now RHEL3 and 4 are very good.
proper-x-server-authorization
Yes, it seems that Cadence works fine on both Fedora 6 (as ramy said) and RHEL5 (beta2). My problem was not in the SO, but in my software. Sorry for missleading... Goodluck!
extension: 153 (render)
I think RHEL 4 it's very good.
fedora core with eda tools
why saying that ain't all the tools running in a correct on it?
cadence tools compatibility fedora
Hi, ramy_maia. Could you send me your script for runing cadence tools on fc6. really appreciate it !
I had some glibc problem with icfb when I tried to run it on FC6. I installed it on FC4, no problem.
variables in fedora 6
what do you mean by scripts do you mean the icms and icfb files? or do you mean the env. variables that i use?
fedora core 32 enable backing store
Yeah, I mean the ENV that you set up for the ic5 on fc6. With the default ENV I set up for FC4, I could not run it on fc6. it always prompts glibc error. and then I tried to solve the compatible libc problems by setting up old glibc env. It comes up with floating exception error. So, I don't know how to run IC5 on fc6.
fedora ic design
Is RHEL 3.0 compatible with ic5.033? if yes, does need any special change or setup?
fedora 10 x11r
I could not quite understand your solution, I understand as you proposed to link da_ic to /usr/bin then copy it to /usr/X86 , am i right?
i did them but still the same problem occurs
i will appreciate any assitance
icstudio cannot connect to display
i am not sure if i understand what you did but what i meant is to
make a symbolic link for the folder "bin" in the "/etc " and put that link in this path "/usr/X11R6" and make sure that that link is named as "bin"
fedora qt invalid version
thanks ramy i solved the problem now, but facing with another one now
$MGC_HOME/icflow_home/lib/libmrdp.so: cannot restore segment prot after r eloc: Permission denied
i am trying to run as su
libstdc++-libc6.1-1.so.2 fc 10
FC6 uses xorg 7.x, which is so-called modular X, and the paths for X window files are changed totally. Sometimes one has to figure out where and what are missing to make the EDA tools back to normal.
/usr/x11r6 fedora 10 kein
You should better try to update IC tools.
The latest IC5141usr4 can be easily installed in FC6 or RHEL5. The previous IC5141 (IC5141usr1-3) really don`t run in FC6 because of the NPTL problem.
backing store in rhel4
I'm sorry, but I don't get what the solution is either:
Hope it Helps
Post30 Mar 2007 14:52 Fedora Core 6 and IC Design Tools
I already has /usr/X11R/bin existing and so I cannot create another /bin in /usr/X11R -> /usr/bin.
Please help.
Thanks!
xserver backing store disabled in rhel
for KL11
copy the files under the original /usr/X11R/bin folder to /usr/bin
then delete the original /usr/X11R/bin folder and make the link of /usr/bin under /usr/X11R/
