kathmandu
Full Member level 5
Don't see a difference. Usual "desaturation" circuits are covering both cases.
For a switching Mosfet (one of the h-bridge's switches), I have to continuously monitor a Vds in 0-48VDC range while for this steady conduction mode Mosfet the normal operation Vds is in 0-500mV range.
There are hall sensors with < 10 µs (even down to 1 or 2 µs) response time.
Do you think that using an analog comparator (op amp) to detect this low voltage peak value (500mV) won't be reliable/fast enough?
My actual LEM sensor has a response time of 7us but I thought it wasn't fast enough. Anyway, I might use a comparator to check it's output, too (beside that Vds monitoring).
If there's no significant downside, I'd like to start designing/building this electronic fuse.
