kathmandu
Full Member level 5
Hello,
I want to design a shoot-through (and short-circuit) protection for a Mosfet full-bridge.
Currently, I have a LEM current transducer on the positive rail (DC-link) and I'm reading its output every 100us using an ADC (for power monitoring purpose only).
Anyway, I don't think that polling interval is short enough to save the Mosfets on a short-circuit/shoot-through condition.
As the current transducer has a detection time of around 7us, I thought of using an analog comparator (op amp) to continuously check the transducer output voltage against a manual-adjusted threshold (maximum allowed current).
That way, it could disable the Mosfet drivers faster than any software detection (ADC/MCU).
Here comes my question: is that delay (7us) short enough to protect the power Mosfets?
Maybe using a shunt resistor would be faster but: (1) I prefer a non-invasive solution and (2) the Mosfet current is quite large (100A) thus I'll need a shunt resistor with a very low value (1mOhm?) so any parasitic resistance (pcb/wires) will affect the current readings.
Thanks in advance for any suggestion.
