Armani09
Newbie
- Joined
- Dec 10, 2024
- Messages
- 1
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 0
- Activity points
- 28
Lack of CODE or SYNTAX Tags
Hello! I'm making a project using esp8266. When the fire sensor, rain sensor, and smoke sensor triggers the solenoid lock should be unlock and will sent a notification thru blynk app. My problem is the solenoid lock is not working. Is their wrong with the code?
Code C - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 #define BLYNK_PRINT Serial #include <ESP8266WiFi.h> #include <BlynkSimpleEsp8266.h> // Replace with your network credentials char ssid[] = "404 Not Found"; char pass[] = "password"; char auth[] = "9FR_Idlv8jVtc-W9nWoHlHwIr_sD3-ub"; // Pin definitions #define FLAME_SENSOR_PIN D1 #define GAS_SENSOR_PIN A0 #define RAIN_SENSOR_PIN D4 #define BUZZER_PIN D2 #define RELAY_PIN D3 // Thresholds #define GAS_THRESHOLD 300 #define RAIN_THRESHOLD 500 void setup() { Serial.begin(9600); Blynk.begin(auth, ssid, pass); pinMode(FLAME_SENSOR_PIN, INPUT); pinMode(GAS_SENSOR_PIN, INPUT); pinMode(RAIN_SENSOR_PIN, INPUT); pinMode(BUZZER_PIN, OUTPUT); pinMode(RELAY_PIN, OUTPUT); Serial.println("System initialized. Waiting for flame, gas, and rain detection..."); } void loop() { Blynk.run(); // Flame sensor logic int flameStatus = digitalRead(FLAME_SENSOR_PIN); if (flameStatus == LOW) { // Flame detected Serial.println("Flame detected! Activating buzzer and relay..."); Blynk.virtualWrite(V3, "Flame Detected"); Blynk.logEvent("flamealert"); digitalWrite(BUZZER_PIN, HIGH); // Turn on buzzer digitalWrite(RELAY_PIN, HIGH); // Turn on relay } else { // No flame detected Serial.println("No flame detected. Buzzer and relay off."); Blynk.virtualWrite(V3, "No Flame"); digitalWrite(BUZZER_PIN, LOW); // Turn off buzzer digitalWrite(RELAY_PIN, LOW); // Turn off relay } // Gas sensor logic int gasValue = analogRead(GAS_SENSOR_PIN); Serial.print("Gas level: "); Serial.println(gasValue); Blynk.virtualWrite(V1, gasValue); if (gasValue > GAS_THRESHOLD) { // Gas detected Serial.println("Gas detected! Activating buzzer and relay..."); Blynk.logEvent("gasalert"); digitalWrite(BUZZER_PIN, HIGH); // Turn on buzzer digitalWrite(RELAY_PIN, HIGH); // Turn on relay } // Rain sensor logic int rainValue = analogRead(RAIN_SENSOR_PIN); Serial.print("Rain level: "); Serial.println(rainValue); if (rainValue < RAIN_THRESHOLD) { // Rain detected Serial.println("Rain detected! Activating buzzer and relay..."); Blynk.virtualWrite(V2, "Rain Detected"); Blynk.logEvent("rainalert"); digitalWrite(BUZZER_PIN, HIGH); // Turn on buzzer digitalWrite(RELAY_PIN, HIGH); // Turn on relay } else { // No rain detected Serial.println("No rain detected."); Blynk.virtualWrite(V2, "No Rain"); digitalWrite(BUZZER_PIN, LOW); // Turn off buzzer } delay(2000); }
