vamanan
Full Member level 2
- Joined
- Aug 9, 2005
- Messages
- 135
- Helped
- 10
- Reputation
- 20
- Reaction score
- 4
- Trophy points
- 1,298
- Location
- India the Great
- Activity points
- 2,286
Hi All,
I recently designed a flow meter using MSP430 and did some EMI/EMC test. When ESD test was done, the unit reset immediately when High voltage was in contact with the body which was earthed. Give me a solution how to resolve the problem. I have a 30 multiplexed seven segment display in another board which was interfaced with the motherboard with FRC cable. When I remove the cable from the display board, the unit is not getting reset during ESD test. When I connect the FRC cable the unit resets during ESD test. Any suggestions or guidelines from your side.....
Regards,
Vamanan
Regards,
Vamanan
