pranam77
Advanced Member level 5
atmel programming failed isp
If the chip is locked due to a wrong fuse settings, probably you can open it with various techniques mentioned here as many have found one or the other technique as usefull. But if the chip is damaged due to some reason, there is no way getting it right. Confirm your chip is ok and it is only the wrong fuse settings you need to reset. Good luck
badre2911 said:hi,
i have atmega128 locked, i have tested with stk500 parrallel programma but failed, a window appear showing the clock div etc ..i have tested with program show in this forum with a cable parrallel and isp connected in my dev board and fail (can't sync).my atmega is solder cms in a devboard, touch xtal1 with finger is impossible.How can i dow please, must be buy another devboard ?
thanks for your response
