Enabling or Disabling the pin in AT89C51 in C
Ohh I see.
And I have already tried with if((P2^1 == 0)&&(P2^0 == 0))
But yet result was same as I described above.
When LDR is dark and button is pressed then the LED at P1.0 should glow. It means its cathode which is connected at pin P1.0 should at low when LDR is dark and button is pressed.
[syntax=c]
#include <reg51.h>
int main(){
P2 |= 0x03;   // Set P2.0 and P2.1 as input
P1 &= 0x00;  // Clear P1
while(1){
if((P2_1 == 0)&&(P2_0 == 0)) // Button Pressed, LDR dark
   P1 &= 0xFE; // LED on
else
  P1 |= 0x01; // LED off
[/syntax]
@pradhan.rachit
heheheheheh....
I have also tried it already :)
You know, in this case LED at P1.0 is always on. No matter what other conditions are. It will not go off in any condition.
When do you want the LED to turn ON and when do you want it to be OFF ? Tell the conditions for LED ON and OFF.
Reactions: Eshal
    Eshal
