It is for measuring furnace temperature
As you are giving information in small portions, one would presume that it is forge for metal molten, and in that case the environment 125 degrees above mentioned now would make sense.
By the way, an idea for cooling I saw in a local TV documentary long time ago, it was presented a very creative solution for decrease the temperature on the vivarium shed of a chicken farm in an extremely hot region: A ceramic clay pipe was buried 10m deep down in the ground, 10m outward, rising there 10m, that is, an "U" shape, pulling hot air from the ouside environment, exchanging heat in the subsoil, and injecting it inside; no freon gas compressor needed, no peltier cells needed, just a a fan. It was interesting how much the air was cooled in the path; I can bet this would reduce some tens of degrees the temperature in your system, and once the air flow necessary to cool a board is quite small, even a smaller scale apparatus would do the job; you will probably have restrictions to implement this, but I leave the suggestion here just for the sake of sharing the information.
