Electronic Pulse changer Help & advice required please.
Well Hello again...
Just stumbled on the link I had saved for this topic so thought I would just give a quick update.
I got the bike on the road, so was able to fully test the converter that Brian designed for me....it works perfectly.
I did a few runs through them signs that display your speed when you approach them and the converter is spot on.
I still have the bike with the converter fitted although it hasn't turned a wheel for a year or so.
So there you go....a belated review of your hard work Brian.
Thanks again.
Regards, Joe.
Better late than never.
I'm pleased it worked. If anyone is interested, I've attached the MPLAB project files. It should import into MPLABX, I haven't tried it. MPLABX wasn't released when I wote the original code!
Brian.
  • speedo_mplab.zip
Reactions: jojoe
    jojoe
