WimRFP
Advanced Member level 5
- Joined
- Apr 16, 2010
- Messages
- 1,589
- Helped
- 594
- Reputation
- 1,176
- Reaction score
- 538
- Trophy points
- 1,393
- Location
- Netherlands
- Activity points
- 15,026
oscillator phase noise was -110 dBm/Hz at 10 dBm carrier power.
Consider we take the noise of the switch into account when it reaches 1/4 of oscillator phase noise - 6 dB below.
So 110-6-(-174) = 48 dB.
We dont care about switch noise figure until it is 48 dB. Or about 20000 times more than given 4 dB... That's just ridiculous
So why do we tend to minimize it if it is so negligible?
Read carefully about SNRin and SNRout: https://en.wikipedia.org/wiki/Noise_figure
What did I miss from your reference? Who is "we"?
Acceptable Noise Figure depends on your application. If you are working with low level signals it does matter generally. Example: Switch between UHF antenna system and low noise amplifier.
When dealing with signals in the dBm range F is not important in most cases. Example Switch between a PA and an antenna system, here other things like power handling and IMD are of importance.
