ds-cdma simulation model in matlab
urwelcome
Banned
Member level 5
Rayleigh fading
I have seen the formula to generate rayleigh distribution as:
h_block=randn(512,1)+j*randn(512,1)*pathloss
than
h=reshape(h_block,1,512)
could you please explain it,how is this rayleigh ??
Thank you very much.
Re: Rayleigh fading
it looks to me some short of function in 'C' programming. Please look in to your code to find where it is related.
    urwelcome
Re: Rayleigh fading
This is matlab program
"h_block" gives a complex matrix of order 512 by 1
"h" just reshape it into a matrix of order 1 by 512
I want to ask is this is the correct way to define rayleigh channel
by the pathloss is defined to be 1,one.
Re: Rayleigh fading
Are you sampling the data over certain time frame?
Rayleigh approximation is generally used to approximate channel fading where there are too many objects and there is no line of sight between transmitter and receiver. So, you may sample the data over 1 sec of time period. I think you can give any number of large matrix. More data, better you will get approximation. If you have some reference paper or some more detailed statements please provide me. I am happy to help you out more and have more detail discussion.
    urwelcome
Re: Rayleigh fading
Can u tell me the all of the ways to generate rayleigh channel effect
like adding two Gaussian random variables
and so forth
