xorcise
Full Member level 2
diy led moving display
Allegro sells a nice high source-current serial to parallel IC... good for the anodes (you would need 10 for a row of 80):
And I've found the ideal (ideally small TO92) NPN sink transistor, at about 5A, a Fairchild KSC5019:
https://www.fairchildsemi.com/ds/KS/KSC5019.pdf
You could also use a 74HC595 to drive the sink transistors. All said, I could envision driving the whole display with a single 8-pin PIC just to prove the point...
